Es wurde ja in anderen Beiträgen schon "heiß" diskutiert, aber hier gibts mal ein paar Stichfeste News aus der Betriebsanleitung die in England schon verfügbar ist. Sorge war ja das Ladeverhalten des LFP Akkus falls keine Vorheizung vorhanden wäre.
Besonders interessant:
Heating pad
The traction battery is equipped with a heating pad that automatically activates when the temperature is too low.
This system is designed to optimise both load performance and driving behaviour (acceleration...) of the vehicle.
It operates in the following situations:
Depending on the situation, activation of the heating pad may lead to:
Charging
The vehicle is equipped with two charging connections located at the front of the vehicle :
To ensure proper battery charge status management and accurate dashboard display of remaining range: charge your vehicle to 100% at least once a month or every 1,000 km.
Das Heizpad ist wirklich eine hervorragende Neuigkeit würde ich behaupten! Hier nochmal der Link zur PDF.
Heating pad
- during AC (alternating current) or DC (direct current) charging;
- while driving;
- during cabin air preconditioning;
- a reduction in vehicle range when unplugged
- increased energy consumption when the vehicle is plugged in.
Charging
- socket for charging up to 7 kW in alternating current (AC) ;
- socket depending on the vehicle, for rapid charging in direct current (DC).
