improve aerodynamics
Viele Autos haben an der Front Stoßstange, rechts/links Öffnungen, wie das abgebildete weiße Fahrzeug. Der Spring hat da eine Blende die keinen LuftstromIMG_20240728_073414.webpIMG_20240728_073440.webp durchlässt. Was macht der Unterschied in der Aerodinamic aus?
Wenn "xxx" offen, wäre es nicht "aerodinamischer " ?
i thought the same, but is not so easy to create a hole like that, especially because you need to create the duct in the back and you risk to have a negative impact on the side of the car.
I would do some tests with that, but maybe covering the whole area with a transparent plexiglass sheet to have a plain surface instead of opening the hole could be an other possible solution.
The idea with the Plexiglas would be the best!
Yeah... I already bought 1 plexi sheet, the question is how to safely fix that on the car
I know a material basic is silicone. But I am not at home to have a look for...Such seems the best, because you can remove it afterwards.
