Greetings from Italy
Fabio Java
Northern Italy
CCS, homemade frunk.
Two months ago a Spring (45 confort plus, silver gray) reached our family.
We already own two Twizys, so now we have three electic vehicles.
Driving the Spring is funny, despite "klong" noise (already hearable) and the need to fight with the fog on the windows.
I already installed some mods I read about in this forum and I thank you for the useful informations I found here.
Sorry if I write in english but writing in german isn't possible for me. If this isn't allowed, please let me know and I'll stop.
Welcome! I think most people can read english, so this should'nt be a problem. Some use Translation Apps.
How cold can it be in Italy, that you have Mist in the car?
@Fabio Java
Ecco come si deumidifica l'auto:
Quindi aria condizionata, AC, accesa, circolazione dell'aria interna accesa, riscaldamento su 2 griglie prima delle ore 12, ventola sul livello 2, le due uscite sopra l'infotainment ciascuna impostata al massimo all'esterno, la distribuzione della ventola nella nota posizione delle ore 11..., e dopo 4 minuti tutto nella parte anteriore è completamente sgombro, dopo 6 minuti qualcosa succede anche sul lunotto posteriore, SENZA riscaldamento elettrico dei finestrini, si badi bene.
La deumidificazione tramite il compressore AC funziona in modo eccellente..., provatela.
This is how you dehumidify your car:
So air conditioning, AC, on, interior air circulation on, heating on 2 grids before 12 o'clock, blower on level 2, the two outlets above the infotainment each set to maximum outside, the blower distribution to the familiar 11 o'clock position..., and after 4 minutes everything in the front is totally clear, after 6 minutes it is also doing well on the rear window, WITHOUT electric window heating, mind you.
Dehumidifying via the AC compressor works excellently..., try it out.
So entfeuchtest Du Dein Auto:
Also Klimaanlage, AC, an, Innenraum-Umluft an, Heizung auf 2 Raster vor 12 Uhr, Gebläse auf Stufe 2, die beiden Ausgänge über dem Infotainment jeweils maximal nach außen gestellt, die Gebläse Verteilung auf die bekannte 11 Uhr Position..., und nach 4 Minuten ist vorne alles total frei, nach 6 Minuten tut sich auch was an der Heckscheibe, OHNE Elektroscheibenheizung, wohlgemerkt.
Das entfeuchten über den AC Kompressor funktioniert hervorragend..., mal ausprobieren.
...saluti cordiali di Bad Honnef
(y)
welcome, i am new as well ... i got mine yesterday ... its a big toy ... and much to discover .. have fun ... greetings from romania
Hello everybody,
thanks for great phorum.
My Spring 33kw with DCcharging:
Bought november 2022
november2023 23000km
average consumption:
Summer 12,5kWh -normal drivig(racing :) ) sometimes highways without airconditioner
winter 16kWh -ECO mode sometimes highways with heating/pre-heating
SOH (%):
new car November2022
100km 98,14%
1000km 98,10%
1800km 98,04%
2400km 97,97% (new software -heating problem)
2800km 97,94%
3000km 97,93%
3900km 97,87%
4600km 97,86%
6000km 97,73%
8300km 97,65%
9000km 97,61%
9700km 97.51%
10000km 97.47%
11000km 97.37%
13000km 97.20%
15000km 96.94%
16000km 96.76%
17000km 96.67%
20000km 96.50%
21000km 96.47%
22000km 96.42%
23000km 96.38%
Partial charging cycles: 700
Full charging cycles:7
charging 95% from solar 7kW
5% DC fast charging
Spring is great car for daily use!
Hello everybody,
SOH (%):
100km 98,14%
1000km 98,10%
1800km 98,04%
2800km 97,94%
3000km 97,93%
3900km 97,87%
4600km 97,86%
6000km 97,73%
8300km 97,65%
9000km 97,61%
9700km 97.51%
10000km 97.47%
11000km 97.37%
13000km 97.20%
15000km 96.94%
16000km 96.76%
17000km 96.67%
20000km 96.50%
21000km 96.47%
22000km 96.42%
230000km 96.38%
5% DC fast charging
da ist eine NULL zu viel im letzten Wert
Ahojte všetkých,
Ďakujem za skvelé fórum.
Väčšina výkonu každého 33 kW a každého možné nasledujúce:
Kúpené v novembri 2022
November 2023, 23 000 km
priemerná spotreba:
Leto 12,5 kWh - normálna jazda (preteky :) ), niekedy diaľnice bez klimatizácie
zima 16 kWh - režim ECO niekedy diaľnice s kúrením/predhrievaním
SOH (%):
nové auto november 2022
100 km 98,14 %
1000 km 98,10 %
1800 km 98,04 %
2400 km 97,97 % (nový softvér - problém s kúrením)
2800 km 97,94 %
3000 km 97,93 %
3900 km 97,87 %
4600 km 97,86 %
6000 km 97,73 %
8300 km 97,65 %
9000 km 97,61 %
9700 km 97,51 %
10 000 km 97,47 %
11 000 km 97,37 %
13 000 km 97,20 %
15 000 km 96,94 %
16 000 km 96,76 %
17 000 km 96,67 %
20 000 km 96,50 %
21 000 km 96,47 %
22 000 km 96,42 %
23 000 km 96,38 %
Čiastočné nabíjacie cykly: 700
Maximálny čas cyklu: 7
Nabíjanie 95% slnečnej energie 7 kW
5% rýchle nabíjanie jednosmerným prúdom
[PRILOH=plné]10886[/PRILOH]
Áno, môžete ísť autom na správne miesto!
100 km 98,14
1000 km 98,10
1800 km 98,04
2400 km 97,97
2800 km 97,94
3000 km 97,93
3900 km 97,87
4600 km 97,86
6000 km 97,73
8300 km 97,65
9000 km 97,61
9700 km 97,51
10 000 km 97,47
11 000 km 97,37
13 000 km 97,20
15 000 km 96,94
16 000 km 96,76
17 000 km 96,67
20 000 km 96,50
21 000 km 96,47
22 000 km 96,42
23 000 km 96,38
24 000 km 96,31
25 000 km 96,26
26 000 km 96,21
27 000 km 96,19
28 000 km 96,17
29 000 km 96,14
30 000 km 96,06
31 000 km 96,00
32 000 km 95,94
33 000 km 95,92
34 000 km 95,88
35 000 km 95,80
36 000 km 95,74
37 000 km 95,72
38 000 km 95,66
39 000 km 95,50
40 000 km 95,43
41 000 km 95,37
42 000 km 95,27
43 000 km 95,20
44 000 km 95,16
45 000 km 95,11
46 000 km 95,07
47 000 km 95,03
48 000 km 94,96
49 000 km 94,93
50 000 km 94,88
51 000 km 94,85
52 000 km 94,82
53 000 km 94,79
54 000 km 94,74
55 000 km 94,71
56 000 km 94,68
57 000 km 94,64
58 000 km 94,55
59 000 km 94,50
60 000 km 94,36
61 000 km 94,29
62 000 km 94,22
63 000 km 94,17
64 000 km 94,13
65 000 km 94,09
66 000 km 94,04
67 000 km 94,04
68 000 km 94,02
69 000 km 94,00
Wenn du jetzt noch das Datum zu jedem SOH hättest wäre das Klasse. 👍
